show vpex stacking
show vpex stacking
Description
In an Extended Edge on stacking environment, this command shows Virtual Port Extender (VPEX) information for all nodes in the topology.
Syntax Description
vpex Specifies Virtual Port Extender (VPEX).
stacking Specifies VPEX stacking information.
Default
N/A.
Usage Guidelines
This command is only available in dot1BR controlling bridges and not available on other stackables.
The following example shows VPEX stacking information:
Node MAC Address   Slot Flags
    *00:11:22:33:44:55  1   eEmc-
     00:00:44:33:22:11  2   e--c-
     00:99:88:77:66:55  3   e--cA
* - Indicates this node
Flags: (e) VPEX enabled setting is on, (E) VPEX is Active,
       (m) VPEX MLAG mode is configured, (c) VPEX-capable node,
       (A) Active stack node
This command was first available in ExtremeXOS 31.4.
Platform Availability
This command is available on ExtremeSwitching 5420 and 5520 series switches, and Extreme 7520-48Y switches.
